TA question
Old Nov 20, 2006 | 10:48 PM
m1candelaa1's Avatar
Default TA question
Im looking at purchasing a new TA but i dont know anything about this.I dont see the diffrence in buying a TA relocationg kit or UMI tunnel brace mounted torque arm,i would appreciate any help guys...
Old Nov 21, 2006 | 10:38 AM
Ouija's Avatar
The relocation kits get the torque arm off the tail of the transmission so you won't break off tail shafts in high HP applications with a hard launch.
The stock torque arm is a stamped piece of metal that I've seen fail on a car with only 300HP.
The relocation kits are typically added to an aftermarket torque arm.
Most people replacing their torque arms today go with one that mounts to the tunnel of the car instead of the transmission.
Only real reason to mount to the transmission instead of the body is to reduce vibrations.
Many torque arms are adjustable, and include a driveshaft loop so you can kill 2 birds with one stone.
Old Nov 21, 2006 | 08:08 PM
CW00BlackTA's Avatar
Relocation kits take it off the trans as stated. They also allow you to run a longer arm which is better for road racing. The shorter body mounted TA's are better for drag applications. Depends on what you want to do.
Old Nov 21, 2006 | 09:32 PM
Ouija's Avatar
Good point CW, I forgot about that one!
Old Nov 22, 2006 | 08:39 PM
Teamwork!
Old Nov 23, 2006 | 12:24 AM
thanks for the help folks im going to go with TA relocation kit since its going to be my DD.TEAMWORK.
Old Nov 24, 2006 | 02:52 AM
01sscam's Avatar
Man-Crush Warning
Don't mean to hi-jack the thread. but i'm currently running the 10-bolt. I want to purchase a chrome-moly UMI torque arm but I don't know which one to get. I have the TSP true Duals, I know one of them is made to clear the duals better. also I plan on doing a 9" at one point.
Old Nov 24, 2006 | 08:52 AM
UMI Performance's Avatar
Hello,
Here is the torque arm for the TSP True Duals- www.umiperformance.com/2205.aspx
This torque arm we work on both the factory 10-Bolt and a 9" rear end.
If I can help anymore please ask. Thank you!
Ryan
