Speed Bumps w/ Koni's. >:(
I've got the Koni SA's on the lower perch and heater hose mod. I went this route because I didn't want to worry about every little bump in the road. Unfortunately, even minor speed bumps are a PITA to get over. I've already destroyed my cats.
Is this normal?
Is this normal?
Wow what kind of speed bumps are you going over? It takes a good one to even hit my dumped duals with turndowns. My car has the WS.6 4x4 offroad suspension option though so thats probably helping.
Any time you lower, you've got to change your driving style or learn to enjoy scraping. At stock ride height with stock cats and y-pipe, I scraped on some speed bumps. After lowering, I had to learn to avoid them altogether. I'm much more aware of driveways, speed bumps and bumpy roads.
-Mike
-Mike
Yeah, I know you/re right. I don't know how you guys who really slam your cars can even drive them. I'm lowered a grand total of 3/4", and speed bumps > me.
Oh well. I'm getting some 18" Z06's soon. Hopefully that'll help a little.
Thanks for letting me vent. (I had just taken a non painted speed bump @ 15mph)
Copy & Paste Moderator
Originally Posted by rocket22
Going 18's will make alittle worse because taking sidewall out the tire and it will lower the car alittle more.
Its the overall diameter of the tire thats of concern. You can have 18" wheel and tire combo with the same overall diameter as the stock 16" wheel and tire combo.
Is this normal?
Is this normal?
I didn't do a 'before' measurment. If you like, I can go out tonight and measure to the tops of the wheel wells for you.
I can tell you that even with this irritation, the mod was WELL worth it. Car handles like a totally different animal.
With 285/40/R17 tires (bald) My front sits at 27 1/8", and the rear sits at 27 3/8".
So it wasn't much of a drop from stock I see. Just enough to make speed bumps annoying. :shrug:
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
LS1TECH Sponsor
Hope I helped.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Yes, you did. I drove a friends car last night, that has a Pro-kit and the SLP version of the Bilstein's...not the re-valves I "thought" he had. To be brief, didn't like it. But...he called an acquaintance that has a Koni SA 4/3 set-up, and I'll drive that tonight.
LS1TECH Sponsor
Does this other guy have stock springs or not? Remember, you have take all the differences into account. Hopefully his car is stock but for the shocks so you can get a good idea. Even then, the shocks can be changed, you'll only be feeling them @ a particular setting, but I'm sure you'll find it much better regardless of what it is.
__________________
Here in SoCal, they make speed bumps that only trucks can get over.
LS1TECH Sponsor
Yeah, it's about 5/8"-3/4" or so on the lower perch.
__________________
