Quick question...Can I install a Panhard bar in my garage?
Do you do a lot of hard cornering with your garage? If so, you definitely want to install a panhard rod in it. (sorry, couldn't resist...)
Yes, easy installation. check out installuniversity.com
You can install anything in a single car garage.
PHB is cake.
I have rebuilt the front and rear suspension and pulled the tranny 3 times in a single car garage.
I will do a motor swap in there eventually.
PHB is cake.
Just make sure you have the chassis on jack stands and the axle hanging free. Follow the instructions and be careful, make sure the car is supported and not going to go anywhere.
You'll get it done.
LS1Tech Premium Sponsor
Hello, yes you need to grease them with a simple grease gun. Make sure that you use a synthetic based grease. The fittings will be in the panhard bar. If you don't have a synthetic grease you can pick it up from your local auto parts store, marine supply, or directly from us. If you have any questions please let me know.
