LCA relocation bracket questions
thanks
We have not had a problem ever with a bolt on set or have I ever seen a problem. Welding is just safer because there are no bolts to come loose or damage that can be caused when or if they do. I feel you would be fine with either the bolt-in's or weld-in's. Also they will not require an adjustable torque arm at all. I always recommend the bolt ons if you plan on changing the rear end at a later date.
Hope that helps!
Ryan
www.umiperformance.com/2012.aspx
Thanks!
Ryan
thus less flex= stiffer and better hookups and better performance
plus bolt on is usually more expensive, why not just weld on and never have to wrry about tightening bolts b4 track day
