Need help quick.koni install
Just put it over the stud on the top of the shock and put the mount on there, add the rubber "center" in the top of the mount and tighten it all down. I good coating of antisieze will help make sure it doesn't get stuck to the mount (do the shaft and the nut, etc), or some of us cover the nut and such with grease to prevent rust.
Hope that helps.
Hope that helps.
Yup. that about covers everything i needed to know. Thanks for your help. You wouldnt believe how long it took for me to get that response. Thanks again.
Actually, due to the post timer in the corner of each post, I would believe it.....
Sorry, I wasn't around much today and I didn't see this one until it had been a few hours. Glad to help.
