brake line woes- i gotta question! *pics*
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
i am installing SS brake lines...and seemed to have stripped the PASSENGER rear factory brake line fitting, the part that screws into the SS line....DOH!
Below is a pic, apparently i corssthreaded something along the way eventhough i was VERY careful...as you can see getting it out was a BITCH
![](http://i8.photobucket.com/albums/a4/erikthegoalie/IMG_3756.jpg)
the oem factory hardline will need to be replaced for sure....can I pick one up pre bent from GM? Or am I going to have to bend one on my own?
Also why it it surrounded by a coil of hard wire all the way to the rear end?
Thanks
Erik
Thanks
Erik
Most chain stores sell metric brake lines. So it should be an easy replacement.
The coil is for protection against heat generated by the diff, vibration when attached to the diff and from rocks hitting it while driving.
Buy some cheap fuel line or vacuum hose, split it and it should protect the new line.
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I had the same thing happen to be wile installing braided lines, but on the drivers side. I took the factory line out, measured it, went to Pep Boys, bought a strait line that was close to that size, cut it, bent it, flared it, done. Its obvious when you look at it that I did it and not the factory, but it works. LOL
i have some flare nut wrenches....i used them. thing is, i crossthreaded it like a dumbass, those thing DID NOT want to come out....oh well...
I will see what I can do....I finally decided to just cut the OEM hard lines out that run along the rear end...and I will either get some new lines from GM is they sell them pre bent, or bend my own...
where can I get bubble flared lines?
update***
I just went ahead and bought some metric brake lines that had the bubble flares....and ran my own lines along the rea end out of harms way....its not the prettiest install....but they are for the most part hidden soooo
we shall see
THANKS!
we shall see
THANKS!
BTW, i had to use a small brass coupler for one of the lines because one end had a smaller fitting than the other end..so I can to cut in half a line..and couple it to another line with the bigger fitting....all in all a PITA, but itll work
lets hope we have NO leaks
i used flared wrenches and snugged em real good soooo
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Do you have pics of what you did? 'cause I'm having a hard time following all of that lol. I need to replace one of my brake lines and around here, at AutoZone & Adv. Auto, the clerks tell me to go to the dealer... those pathetic, ******* losers. Oh yeah, where'd you end up buying your bubble flared line from?
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
hey buddy
yeah I can snap some when I get a chance..
Part 1: Here is the deal....ANY decent parts store should have assorted lengths of brake line...with different sized fittings for your application....
Since our cars are as American as fried rice, the fittings are METRIC
...so make sure you are looking for the 3/16" METRIC brake lines.
Part 2: Look specifically for brakes lines for EURO cars, or British (it said EUROPE and BRITAIN over the brake lines at my store, you may have to ask)---those lines have the 'BUBBLE FLARE"--- maybe thats what they use overseas?
Part 3: Depending on which line it is you are replacing, you may have two different size fittings (the small thing that screw into the lines going into your calipers)...
well problem is when you buy aftermarket brake lines, they ONLY come with the same sized fitting at each end which makes for a real problem right??? WRONG- I found out that they make a coupler in which you can join two 3/16" lines in the middle...I will show a pic of that too...that way you can have one line with TWO different fittings at each end....it depends on what line you are replacing (the driver side REAR is the only one that needs differen sized fittings)
Hope this EPIC response helped! Lets just say I learned a lot today!
PM me if you need any more info!
Erik
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Erik
BTW, I called GM, they said "We do not service brake components- you will have to go and make your own" that is verbatum
Um, ok- wow they didnt take my money for once! hahah
