whats the best way to install SFC?
with suspension loaded, meaning use ramps for the front wheels and I used a jack and jack stands as far as i could get them under the rear end closest to the wheels. a ride on lift would be best if u can get access to one.
unbolt the tunnel brace first, then attach sfc to the lca body mounts first and then swing up to the front locations. do one side at a time.
http://www.slponline.com/inst/70802.pdf
