SLP line lock
CULATR - I would recomend using a 20 Amp Pilot duty momentary switch. The same friend said to make sure it says PILOT DUTY. I think it has something to do with the constant load while the button is held down. That's been my challenge. I can't find a 20 AMP Pilot duty switch.
As GETGONE said - I will check Summit and Jegs for the switches rating.
Rats guess ill start looking as well!!
ow and another thing for the flip switch to activate power to my momentary push button switch would this be safe to use 1 x 6A 125VA SPDT paddle switch ?????
If you wired as the direction from SLP says, it's a switched ground. Therefore any short on the switch wire from the dash to the line lock will turn it on. That's why I wired it with a switched positive.
This is the same princuple as removeing the ground wire on the battery first.
Hate to bring back an old thread, but yeah I have this problem. I hooked up all my brakes lines, but have not had the time to do the wiring. I figured it would be fine if I didn't hook up the wires. No power, No problem right? Wrong. I drove the car for about 2 weeks, took a 6 hour trip to my parents there and back no issues. I didn't touch the car for a week or so, went to move it and the line lock was engaged. But as soon as I turn the car off the brakes disengage.
How does the line lock engage with no power going to it?
Also, when I go to wire it this week, does it matter which wire goes on which prong of the solenoid, I wouldn't imagine so, but because cause their directions suck I figured I'd ask anyways.
https://ls1tech.com/forums/manual-transmission/813062-just-bought-slp-line-lock-system-any-install-tips-what-button-do-i-use.html
