brake clucking.
I had the same thing going on at my drivers rear after I changed my pads and rotors, funny tho, it only happened in reverse. everything looked fine, and didnt appear to be loose untill I took the wheel off... The lower caliper bolt had backed out and fallen to the highway gods. Lucky nothing bad happened on that one!!
So, Id recomend pulling your wheel and taking a look.
Originally Posted by RealLiveMD
Right front wheel clucks with braking. Only occasionally and everthing feels tight without taking the wheel off of the tire. Car brakes fine. Any suggestions.
mine used to quack until i fed it some breadcrumbs
