few questions
I had a few things I wanted to change......
1: the rear end is not centered, so I plan on getting an Adjustable PHB, and then get it aligned professionaly.
2: When I am not moving fast, like around 20MPH in a neighborhood, the wheel s much harder to turn then when I'm cruising. Much, much more so then in my bro's corrola........just curious if that was normal.
3: Is the shock tower brace a good part for a DD car?
4: Same for SFC's?
5: Shocks first?
This isn't going to be going to the strip, so I need a suspension that handles well. What order should I get the above parts? Shocks first?
I also dont have rims/tires picked out either.......
any good thoughts?
Then a GOOD alingment. Factory alignment is intended to produce a "push". My $.02: ZERO toe / -1.5 camber / +4.5 caster. Tell the alignment guy what you want, don't let him decide...they seem to always want to do stock: cross camber and all that...not intended for the enthusiast stuff.
Then wheels/tires-or b4 alignment if u can swing it. Pay the $ for good high perf tires. My Nittos 555s r a good compromise...300 treadware, can still drive in rain, but stick well at the track, and not over the top expensive (plus Discount tire direct offers great wheel/tire packages w free mount/balance/ship).
Later Strano Sway Bars.
STB-I have one, but question if its really needed. 4th gens do not have the need 4 it 3rd gens did (when they were truely "strut towers"). SFCs...I had them also...may put some on again later...not sure how necessary they realy r either.
As 4 the steering thing, expect more effort at low speed, but cannot really tell if its "normal" effort from here.
