Rotor from hell
Old Jan 7, 2007 | 02:52 AM
flyin red TA's Avatar
Default Rotor from hell
The passenger side front rotor will not come off no matter what. I hammered it, torched it, soaked it in WD40, and later jacked it up to the sky so I could do a baseball swing with a 5lb sledge. You wouldn't believe the chunks I knocked off of it, and it still wouldn't budge.
Is there a 3 prong puller big enough to fit on this piece of #(@&#$ ?
My only other solution is to get crazy with a cutting disc.
Old Jan 7, 2007 | 04:26 AM
roy's Avatar
roy
Sounds like you might have done damaged the wheel bearing if the rotor chunking form hammering it. Might be simpler to bolt a W/B spindle assembly to it now.
Old Jan 7, 2007 | 10:37 AM
trackbird's Avatar
My next move would be to drill through the hub area of the disc. I'd then try to crack it in half. If the wheel bearing is ok after that, then great, if you get it back together and it's noisy, it may be time for a new wheel bearing. If you beat on those bearing/hub assemblies hard enough, you can damage them. You're possibly close to that limit.
Old Jan 7, 2007 | 01:50 PM
ccsanders01's Avatar
heat it up again then cold shock it with ice cold water
