G-tech
Old Jan 11, 2007 | 10:36 AM
orangefun's Avatar
Default G-tech for measuring G's
anyone out there use a g-tech to measure lateral G's? are they close? what are your guys thoughts?
Old Jan 11, 2007 | 12:16 PM
orangefun's Avatar
anyone???????????????????????????????????????????? ?????????????
Old Jan 11, 2007 | 02:52 PM
02NHRAtransAm's Avatar
my thoughts..... u are j/k man.... u know i dont have a gtech....
Old Jan 11, 2007 | 03:21 PM
jimmyblue's Avatar
Moderator
I played with my "G-Tech Pro" (old style) some and if
you null it properly, it's a fairly accurate piece. I have
also built a 2-axis accelerometer which outputs +/- 2g
as voltages for fore/aft and lateral acceleration, that
I log with my HPTuners MPVI EIO cable. I like that
better and haven't used the G-Tech since.
I think your main inaccuracy will be the error of any
body roll, adding gravity*sin(roll angle) into the
measured acceleration.
Other than that kind of thing, silicon accelerometers
seem to be very accurate. Datasheets usually claim
sub-% measurement accuracies. If you turn it on
its side and it says 1.00g, call it sub-% for the box
and just make sure you have the nulling and the
orientation dead right.
Old Jan 11, 2007 | 03:54 PM
orangefun's Avatar
I know how to mount it were is doesn't move, but I was playing with it and got a .96 latteral g out of it. just wondering how close it was to being right.
Old Jan 11, 2007 | 05:58 PM
koolaid_kid's Avatar
I have one of the original gtechs, but have not used it for lateral g forces. However, I have a lot of experience with accelerometers (working for the Navy on guidance systems) and they tend to be fairly accurate.
However, unless you have upgraded your tires/suspension I would question such a high reading. I suggest insuring that you have calibrated it correctly prior to running your tests.
If you have upgraded your suspension/tires, that reading is not totally unreasonable.
Old Jan 12, 2007 | 01:55 AM
orangefun's Avatar
I have very sticky tires(275 40 17) adj pan hard bar, sub frames, sport lines, relocation brackets, 32mm front bar and a small 19mm rear I had a shop put better sturts and shockes but I can't remember what kind.
