LG panhard Bod issues
Old Jan 13, 2007 | 08:56 AM
Goldstreak65's Avatar
Default LG panhard Bod issues
Has anyone had trouble with the LG Motorsports PHB fitting correctly into the brackets on the car with the provided spacers they give you? My car is a 3.8 does that make a difference?
Old Jan 13, 2007 | 09:53 AM
Fulton 1's Avatar
Does the OEM bolt not fit with the spacers? IIRC the PHR requires different spacer ID's for the fwd vs the aft side of the fitting because the bolt is stepped. In other words, not all four spacers you get will be the same size. I'd check and make sure that they sent you the correct size spacers and, if so, that you're using the correct spacers in the correct location.
Old Jan 13, 2007 | 08:33 PM
Sorry man I wasn''t clear, My car is a 2000 3.8 camaro and I bought a LG motorsports PHB and the spacers that come with it for the rod ends are too big. The bolt fits thorugh the spacers just fine its just that they make it too wide to fit into the bracket.
Old Jan 13, 2007 | 08:43 PM
Fulton 1's Avatar
Any chance you could get some pics of the condition? Maybe they just sent you the wrong spacers, but it seems odd if they fit those particular bolts that they would be too long...
Old Jan 13, 2007 | 10:57 PM
mitchntx's Avatar
Geez man ... spread the mount open to get the assembly in. Once you torque the bolt/nut, it will squeeze to fit.
Old Jan 13, 2007 | 11:35 PM
Andros's Avatar
I have the G2 phb which is the same irc. and the spacers for the pass. sidew fit fine but only 1 spacer for the driver side fit, but I left it like that. its working fine without it as long as its tight
Old Jan 13, 2007 | 11:39 PM
SHINER's Avatar
had a hard time today with my BMR PHB. I played with it for about 30 mins before it decided to go in.
Use a Big crowbar to help align the hole and a screw driver to have them line up.
Old Jan 14, 2007 | 12:29 AM
I would have to spread the mount open about an inch. I bought the bar from a member on this board and he never used it.He included all the spacers and dust covers for the double rod ends that it came with.
I just don't think it would be good to only put one spacer on it, I thought they were suppose to have them on both sides.
Old Jan 14, 2007 | 07:36 AM
mitchntx's Avatar
An inch? That's a lot. We need some pics.
Old Jan 14, 2007 | 08:45 AM
Ok I'll try to get some up tonight after work
Old Jan 14, 2007 | 10:34 AM
Fulton 1's Avatar
Goldstreak, I sent you pm. I think I might know what the problem is...
Old Jan 14, 2007 | 11:00 AM
Fulton, I just sent you a PM.
