my fuel lines are in the way
well im trying to finish up my SFC install and the fuel lines on my 94 are right where the front drivers side SFC are going to bolt up, how do i get around them? so far i just pulled them down and put them below the SFC but will that put the fuel lines at risk to break?
Copy & Paste Moderator
You can move them up one notch on the clip that they are on. The clip has one free notch above the notches used by the 2 fuel lines. Also, the heat shield will have to be trimmed to fit around the SFC.
BTW, which SFCs?
BTW, which SFCs?
BTW, which SFCs?
BTW, which SFCs?
Yes as stated above you can do that, or pull them below, you will have no problems with them. There is plenty of room to move them around. Also there is no heat shield trimming with our set-up.
Hope that helps!
Ryan
