help with clunking (suspension?!?)
Old Jan 20, 2007 | 01:01 AM
slvrta2002's Avatar
Default help with clunking (suspension?!?)
ok here it goes, i have a 2002 TA A4 25,000 miles. i lowered the car 1.5" about 4-5 months ago and now there is a noise (loud clunking) coming from under the car now. it happens when i break hard and then give is some gas. also happens sometimes when it shifts gears. So i started to TRY to fix the problem. poly trans mount....no help........got a BMR non-adj TA with poly mount.............no help.......now it seems to be getting a little worse. could it be the pinion angle? should i have gotten and adj-TA? or is it maybe the u-joint? maybe worn from the different pinon angle or something like that? i have had the car up on jack stands and twisted the Drive shaft it has some play but not tons. it is starting to kill me. i also do not have a pan hard bar. maybe this would fix it? I just have to fix it
Thank you in advance for any help!!!!
Old Jan 20, 2007 | 01:55 AM
Demon Of Dreams's Avatar
**** with the LCA's at all?
and why don't you have a panhard bar?
Old Jan 20, 2007 | 12:17 PM
azibit's Avatar
i just bought a pair from my buddy BMR havn't put them on yet. and I just bought relocation brackets, but again not installed though.......i really don't know why i don't have a panhard bar..................is it a necissity??? could that be making the cluncking noise??? Thanks again
Old Jan 20, 2007 | 10:19 PM
azibit's Avatar
anybody??
Old Jan 20, 2007 | 10:32 PM
sickSS's Avatar
I have the same problem im not sure what it is i have an adj panhard bar so i dont think thats it i dont know what it could be
Old Jan 20, 2007 | 11:41 PM
Ralls's Avatar
So you say the u-joints are loose? Does it clunk when you bump the throttle at a constant speed?
My driveshaft has some play in it too. I get clunks when bumping the throttle cause somethings loose.
Old Jan 21, 2007 | 12:21 AM
azibit's Avatar
if im coasting (not on the gas at all) and then bump the throttle it does clunk. its the most annoying sound i have ever heard out of one of these cars.
Old Jan 21, 2007 | 12:26 AM
Revelation Z28's Avatar
grease the U joints.
i had that problem of bumping the gas in 5th.
took 8 pumps of grease each until it came out of the bearing caps.
Old Jan 21, 2007 | 08:58 AM
Ralls's Avatar
Where exactly do we grease em. There isn't a nipple, so do we just shoot it all in there?
Old Jan 21, 2007 | 01:49 PM
azibit's Avatar
same question where do we grease them???? if thats the only problem im gonna be soooo!!!!!!!!!!!!!!!!!!!!!happy..
Old Jan 21, 2007 | 01:54 PM
theres grease fittings on the stockers i think. previous owner replaced the stockers on mine, but im pretty sure GM put greasables on.
put the *** on jackstands, parking brake off, and rotate the DS until you see the fittings.
i had to take the DS off of the pinion yoke to expose the fitting on that joint.
Old Jan 21, 2007 | 04:44 PM
VIP1's Avatar
Copy & Paste Moderator
You don't have any Panhard rod at all (stock or otherwise)?
If so, stop driving the car until you install one. The Panhard rod keeps the rear alxle from moving side-to-side. It is a necessay suspension component for our suspension design.
Old Jan 21, 2007 | 05:17 PM
Ralls's Avatar
I never seen grease fittings on em before, but I'll double check.
Old Jan 21, 2007 | 06:14 PM
RAMPANT's Avatar
I had something similar, and it was my LCA's. I have a 12 bolt and Spohn LCA's rod/urethane. I had tightened everyting 5 times. I went to change the rod end as the next test and when I dropped the rodend, I found the bushing end was loose. I had to tighen it till I thought I would break the socket and bingo, clunk gone.
When you check tighness you may not have it as tight as you think!
Old Jan 22, 2007 | 11:59 AM
azibit's Avatar
i have lca's and relocation brackets just not installed yet. so i wouldn't think it would be that..........unless............the stock ones vibrated loose or something, well its something to look at! thanks for the help guys if you have any other suggestions let me know, and for as far as the grease fittings, there is still snow all over here have to wait for a decient day.
Old Jan 22, 2007 | 03:05 PM
Ralls's Avatar
Just got under the car. There isn't grease fittings on stock u-joints.
Old Jan 22, 2007 | 03:52 PM
gun5l1ng3r's Avatar
I don't think stock u-joints have grease fittings. They only have little holes w/ plastic in them. Those are the u-joint retainers and you have to melt them off in order to replace the u-joints.
I have a similar clunk too and it almost feels like it is slack in the rear gears.
Old Jan 22, 2007 | 04:28 PM
azibit's Avatar
that's what i first thought slack in the gears, but my car only has 25,000 miles i didn't know if it was logical, because of the low miles..........well...ttt
Old Jan 22, 2007 | 05:18 PM
jb442's Avatar
I have a mysterious "clunk" sound that I'm trying to track down in my car as well... I posted the following in another thread, but it seems appropriate here.
I have a '95 Z28 w/~95K miles on it, and I'm now starting to hear some strange noises from the rear, similar to what you've described. It *usually* happens when the following is true:
1. I've been driving the car for a while (>25 minutes).
2. I'm coming to a stop, and the car is in neutral (M6).
3. My speed is somewhere between 1-10 MPH (usually lower than higher).
The actual sound is hard to describe - Sometimes it's a quick 'clunk-clunk-clunk' sound, and other times it sounds like something is binding, and then popping with a metallic kind of sound. I wish I could somehow record it because that description really doesn't help.
What I do know is that the car is just about stock and the only change recently is to put new shocks and 1" lowering springs on the car, which did changed the pinion angle. Also, the 'clunk' sound was there prior to the suspension upgrade, but it's now much more prominent and frequent.
This past weekend, I checked just about everything I could think of in the rear of the car. I checked the brakes - Rotors not warped, pads looked fine, caliper bolts tight... Checked all suspension bolts, the control arms & torque arm. The TA wasn't bent or cracked. I checked the rear u-joint and it looked fine and was not loose. After that checking, I really couldn't see anything that was obviously worn-out, broken, or loose. Oh yeah, I checked the posi by doing a nice burnout... The traction was pretty even.
I did break out my magnetic-base dial-indicator to check the end-play at outside of the pinion yoke and it was about .045". I'm sure that doesn't equate to what the actual back-lash is between the ring & pinion, and it really didn't seem too bad.
My only *guess* is that when I'm coming to a stop in neutral, the combined slack in the M6 transmission and rear-end, and possibly some kind of interaction with the posi-unit, is causing the clunking sounds.
Old Jan 23, 2007 | 11:05 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
for different cars i've owned the clunk is normal in my opinion. i had 2 2002s both Zs and both would make that clunking. the first one is had was auto and my current is stick. it seems when you hit the throttle and the engine kicks in thru the converter/clutch and hit the rear end, the u joints clunk. that's how i diagnosed it. i've taken my DS down a few times and haven't noticed any grease fittings myself.
