a-arm install help.
Old Jan 21, 2007 | 02:55 PM
FloydSummerOf68's Avatar
Default a-arm install help.
I'm trying to put on my chromoly a-arms from UMI and have run into two problems.
There are two bolts holding it on in the back...one vertical and one horizontal.
The vertical bolt seems to run into the frame a little if I try to press it up, the horizontal one runs into the rubber section on the steering setup....how do I overcome this?
Old Jan 21, 2007 | 09:48 PM
Figured it out
Old Jan 22, 2007 | 02:48 PM
logikal6785's Avatar
What was it?
