LT1 Owners With D/S Rotors
If you replaced your pads also, did you use oem pads or did you get a better set of pads?? I'm just wandering if the better pads will work, because I can't get my calipers to go on my new rotors with the new, thicker pads. and yes, I did compress the caliper using a c-clamp....Any other ideas??
I think it is compressed all the way, they just won't fit with the new rotors, which are the same size as the stock ones. I took some pics, I'll post up later so maybe someone can tell me what is going on. thanks for the input!!
Is there something better to use than a c-clamp to compress the caliper??
