Bad SFC install cause dimples??
. I installed the SFC's as soon as I bought the car to avoid this. I guess it is possible the dimples have been there since I got the car but I highly doubt it(i'm meticulous about the car). Seeing the dimples I decided to check things out. Well on the driver side the picture shows how the SFC isn't flush against the frame rail where the LCA mounts to(about an 8th-16th of an inch gap). Could this have caused the dimples since the SFC is slightly angled down towards the back of the car???Also, I think the dimples appeared after I put the 315's on. The passenger side has no dimples and the SFC is mounted flush to the frame rail.[IMG]
[/IMG] [IMG]
[/IMG] Sorry for the crappy pics the car was on the ground.
Thanks in advance for any input
just depends on the car and its uses.
i have dimples and sfc's and my car only has 20k miles
wtf?! literally every other thread i've read about this says sfc's STOP dimples from forming. my car has 33k miles and i was thinking of getting sfc's as a preventative measure. but if the above is true then i wont.
I had 3-point SFC's on my Z28 and I still got dimples. It's just the car and the way it is.
Bottom line, its all a matter of opinion...seems no one really has the answers.
Who read the feb 2007 GM High-Tech? It has the GM built LS7 4th gen. No SFCs...kinda makes you wonder. They did of course ditch the stock rear.
Link: http://www.gmhightechperformance.com...et_camaro_z28/
j/k. I regret buying black. If i paint it way, way down the road, it's gunna be white to hide most of the ****.
The next time you jack your car up take a look at the rear rails right above the rear axle with a flash light you will see the weak erea im talking about.
