Dragstrip traction?
Old Jan 29, 2007 | 02:23 PM
jeremy341a's Avatar
Default Dragstrip traction?
I am using my 99 Z28 A4 as a dd as well as racing it in the street class. It is mostly stock with a lid, fast toys ram, air, 160 thermo and is on street tires. Without changing tires what is my best bet to improve traction? I actually haven't raced this car yet. My old car had 2.73's this one has 3.23's. My old car had no traction problems but I'm thinking this one might. What suspensions mods would you recomend. I was thinking a set of lower control arms, relocation brackets and new torque arm. Am I on the right track? Do I need anything else? I don't want to get to exotic with such little power.
thanks in advance
Old Jan 29, 2007 | 02:40 PM
Ericbigmac83's Avatar
You prolly wont have any real traction problems anyway. But those will definitely help. I just finished up my LCA's and i can tell a big difference
Old Jan 29, 2007 | 02:54 PM
onephatZ28's Avatar
I went from a 2.8 60ft time to a 1.78 with Comp Engineering Sub Frames and BFG's 255 DR and a 2800 stall, GOOD LUCK
Old Jan 29, 2007 | 02:56 PM
jeremy341a's Avatar
Yeah I was thinking it won't spin much, but I am interested in consistency more than et, so I want it to dead hook.
Old Jan 29, 2007 | 02:59 PM
onephatZ28's Avatar
thanks in advance
I would do the SFC 1st
Old Jan 29, 2007 | 03:36 PM
slick1851's Avatar
My freind put on adj lower control arms, he said it helped out on the car..Hope this helps you...
He wasnt on a DR but a decent street tire
Old Jan 30, 2007 | 01:02 PM
68birdls1's Avatar
you do realize that your sfc did not make that big of a deal in all of that right? mainly the tires
sfc are not really needed that much especially in a street class like you are in and are not wanting to change tires. bud you are definately on the right track with all that you have listed. i think the torque arm will net you the most difference in 60 ft. then i would do the lower control arms and then possibly the relocation brackets.
