Popping from the rearend...
I have a '99 FRC and I lowered it about a month ago. I lowered it as far as it would go on the stock bolts. Afterwards I was hearing a small popping noise from the rear which has now turned into a clunk anytime I take off or transfer any weight onto the rearend. I looked at the rear and it all looks good. The bolts are ar the same position I left them in wen I lowered it. What could this noise be? An help would be greatly appreciated.
Daniel.
Daniel.
i had popping coming from the rear of my car awhile back....one of the shocks bolts came loose and i found it before the end of the bolt came out...it could also be the car settling down on the springs....check the shocks and springs....just my $.02
