****QA1 spring choice****
Old Feb 4, 2007 | 04:55 PM
ninetres's Avatar
Default ****QA1 spring choice****
What exactly is the difference between the 275lb and 300b springs performance wise? I am somewhat of a suspension noob.
Here are my front end specs as far as weight:
6.0 iron block
front mount turbo set up w/ intercooler
TH400
Chromoly PA racing k member
abs delete
manual rack
no a/c
oem upper and lower fron LCAs
I assume the 275 are better for weight transfer but I was just wondering if my car might be better with the 300lb springs because of my heavy iron block. Then again I have quite a bit of weight reduction up front. Help please!
Old Feb 4, 2007 | 09:07 PM
01SLPSS's Avatar
Running 300lb springs on my car
Old Feb 4, 2007 | 09:44 PM
ninetres's Avatar
Why not the 275s?
Old Feb 5, 2007 | 08:18 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by ninetres
Why not the 275s?
The 275# spring is going to give you a very low stance in the front especially with the iron block. If you plan to drive the car a lot on the street the 300# spring are a better choice IMO...You will not have to adjust the coilover to the very top to get a decent ride height. You will not tell any performance difference at the track.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Feb 5, 2007 | 03:19 PM
01SLPSS's Avatar
300's because I do alot of traveling and daily driving and dont want the car nose diving ever where.
