BMR bolt in relocation brackets fit 12 bolt
I figured i'd ask. My 12 bolt will be here next week and either gotta buy some UMI 12 bolt relocation brackets unless there is someway the stock 10 bolt bolt in
relocation brackets will fit....anyone know, i figure they won't though
Thanks
Thanks
If you already have a set try them before buying another set. There is a good chance they will not work though. Moser makes there control arm mounts much wider then the factory rear end and also spaces there shock mounts differently. This is why we have to make a weld in set specifically for Moser rear ends. Try it first and see but I doubt they will work.
Hope that helps,
Ryan
Hope that helps,
Ryan
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If you take and cut the shock mount bracket off, the relocation bracket can be welded on no problem. If you have any questions on how to do this feel free to ask
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Lee Spicher
(813)986-9302
