lca qusetion
Personally I think LCAs are overrated. But if you really want them, get sherical bearings (rod ends) on one or both sides. This will allow the articulation, and eliminate the bushing deflection of the oem rubber bushing. Another, cheaper option is to replace the factory bushings in the stock LCAs w 1LE bushings (harder rubber) or ploy bushings. Bear in mind though that rod ends and ploy bushings will transmit more noise and vibration. Both will also tend to wear faster than OEM rubber.
