car leans
Old Feb 7, 2007 | 06:40 PM
HTX's Avatar
HTX
Default car leans
Hey guys. Ive notcied that my car leans to the right. I have a 99 cmamro w/ 125K miles and my right side of my car sits about a 1-1.5 in. lower than my left. A buddy told me alot of F-Bodies do this.
Do alot of F-Bodies do this?
What could casue this?
What should I look for?
Thanks guys
P.S. stock suspension. except for LCA's and panhard bar.
Old Feb 8, 2007 | 09:22 AM
HTX's Avatar
HTX
bump no one?
Old Feb 8, 2007 | 11:01 PM
Yahelou's Avatar
i had that problem when i first bought my car. it had 107k on it. i heard different stories from everyone includin that the frame of the car was messed up. that kind of made me worry. so i went ahead and changed the shocks and springs. it turns out the previous owner b4 jumped a curb and messed up shocks/springs pretty badly. after changing shocks/springs the lean is not as noticable, and it is not as bad as before, but its still slightly there. maybe .5 inches diff. not to worried about it. the shocks were all original shocks.
Old Feb 9, 2007 | 09:39 AM
TNTramair's Avatar
ive allways heard this was normal cause when you sit in it, its supposed to be perfectly level. which makes sence if you think about it. if your lowered, make sure your panhard rod is adjusted accordingly. hope this helps.
Old Feb 9, 2007 | 12:59 PM
HTX's Avatar
HTX
It does help. Thanks guys.
Old Feb 9, 2007 | 06:02 PM
gun5l1ng3r's Avatar
My car is the opposite.
My dirvers side sits lower by about 1 in (in the back only) than the passenger side.
My car has hit a curb in the rear on the drivers side.
I think that my lower spring perch on the drivers side was installed incorrectly, or at the wrong angle, and thus makes the perch sit lower.
Any help on how to reference where the lower spring perch should be located? (ex: 1.75 in off ground).
Old Feb 12, 2007 | 09:25 PM
gun5l1ng3r's Avatar
Any help on the spring perch location?
Old Feb 13, 2007 | 10:11 AM
chupr0kabra's Avatar
Switch your rear springs around and see if it still leans to the driver's side.
-Mike
Old Feb 13, 2007 | 11:39 AM
gun5l1ng3r's Avatar
Will do, Thanks for the advice.
If it still leans, are the spring perches supposed to be parallel to each other; in other words, are they both at the same height off the ground?
Old Feb 13, 2007 | 01:41 PM
If it leans the other way, you know you've got a spring problem. If it still leans to the driver's side, it's more likely a perch problem.
-Mike
Old Feb 13, 2007 | 02:44 PM
gun5l1ng3r's Avatar
Awesome, that is what I figured.
If it is a perch problem, is there a specific angle that the axle tube needs to be inserted in the pumpkin?
Is was thinking I could always just do the hose mod on the higher side to bring it more even.
Would it be a problem if one side had the stock insulator and one side was the hose mod?
Also I heard, here on LS1Tech, that aligning the springs might help. I tried to align the pigtails(end of the spring) to the rear of the car when I put my Koni's on about a month ago(this problem was there beforce I changed the shocks, it has had this problem for 3 years, since my brother ran it sideways into a curb).
Sorry for the long post. Just trying to get things sorted on my car.
Old Feb 14, 2007 | 10:34 AM
gun5l1ng3r's Avatar
Any more help?
Old Feb 14, 2007 | 10:44 AM
jrgswhitels1's Avatar
All cars have have some degree of offset in height. Critical that measurements are taken at the drip edge to ground. Also critical that the ground is level and even for proper measurements AND make sure that if vehicle is lowered, neg./pos. chamber has to be properly adjusted. Any dimension off by more than 1/2" might include damage to frame/suspension.
Old Feb 14, 2007 | 11:26 AM
HTX's Avatar
HTX
My problem is either the spring or shock. Last night I was driving and my fender (still right side) started grinding into my tires at every little bump. Now the tire is torn to shreds and my fender is cracked. Son of a B!TCH
Old Feb 14, 2007 | 02:54 PM
gun5l1ng3r's Avatar
What is drip edge? My vehicle is stock ride height.
I thought the shop would have fixed the frame. They had it on a frame machine for about a week.
Old Feb 17, 2007 | 09:40 AM
Adnectere's Avatar
I think Strano mentioned something once about a car being tilted like this and that everything was ok with it and you couldn't fix it. Not sure. Maybe the poster should PM him to refer his knowledge to this thread.
Old Feb 17, 2007 | 11:30 AM
Sammich's Avatar
My car does this as well. I emailed Strano about getting a spring/shock set-up to fix this and replace the stock stuff. Hopefully all is fixed once I hear back from him and get a new set-up. Currently on flat and level ground my measurements from ground to top of fender arch are as follows:
Driver front: 27in
Passenger Front: 26 1/2 in
Driver rear: 27 1/2 in
Passneger rear: 26 3/4 in
