lca relocation brackets and worse traction..
my car is lowered and has never really had a "wheel hop" problem but i have some wheel spin. i added some lca relocation brackets last nite and now the wheel spin seems to be twice as bad. i have them on the lowest hole setting and i have yet to heat up the m/t's and try em out.. u think i just need to heat the tires and give em a shot or put them on the next hole up??
Sounds like at least now the power is going to the wheels. Heat up the tires a bit and try them out before you change the holes. Not sure what method you are using to launch but you may have to adjust it slightly as well.
wow, first nice day around here and tried a couple of lil launches.. the lca relocations brackets helped out. just had to heat those m/t's up a bit..
feels like the front tires kinda scoot when i'm turning though. don't know if this is normal with the lca relocator brackets?
