slp or strano??
I'm just happy to hear you think we do a good job. Like anyone, we mess up from time to time, but we try and make sure it's rare and we fix anything we goof.
In my opinion the ride and capabilities of the Bilstien/Eibach combo are not much different from stock. Other than feeling a little lower with better CG, it responded much the same as my car, even when being pushed.
I want a car that feels tighter, so I plan on going with the Strano/Revalves when the time comes.
They don't do springs or shocks (yet)
Um, ok.... I agree but that has nothing to do with what was being asked. I sell UMI stuff and use it all the time. They don't do springs and shocks, and I don't do LCA's and TA's, etc.... as in building them. We work together often, and Ryan refers folks to me for that stuff, and he knows that if the person needs some of the parts he makes, that's what we'll use. Frankly we do different things, that overlap.
That's an excellent description HawkFanatic. SLP fixed the rough edges on the ride above all. SLP stuff handles pretty well, but so does the stock car when there are situations the shocks are trying to screw you. Frankly, the SLP suspension should have been stock, that's what it amounts too. Better than what was stock, and similar to a normal non-sport BMW.
I, like HawkFanatic, prefer something more crisp. Not more harsh, but I don't mine a taut ride and really hate when the car is on the soft side. I'd rather a car be slightly overdamped than underdamped.
How much will SLP lowering springs lower my car? I need no more than 1".
But if your F body springs have 30,000 plus miles on them, brand new SLP springs may not lower your car at all, because your 30,000+ mile OEM springs have weakened and sagged with time.
Thanks for answering my question Don @ SLP
Thanks, Keith
SLP springs tend to lower most cars about 3/4" on average.
Your stock springs are linear BTW, and they are NOT what makes the car harsh, that's the shocks. Ask anyone who's only changed the shocks and left stock springs, the car is 100x better. Linear springs are more consistant in regards to performance and drop.
My springs are have a lifetime guarantee from the company who builds them, and they are guaranteed to be within 2% of the advertised rate. Also they are tempered, shot-peened and have a multi-stage presetting process done.
But basically only crappy metal results in spring sag. But sometimes folks don't assess the before/after and spring rates correctly and confuse a low height with sagging. You pile in a lot of weight, the car will ride lower which looks like sag but isn't.
what headers would you recommend with your springs from a ground clearance point of view?
which headers would you stay away from, when considering ground clearance?
with that being said, same questions, but from a performance point of view.
thanks
tony
BOSS APPROVED!
