The smoothest riding suspension setup?
I'm a newbie when it comes to suspension but i am looking for the smoothest riding suspension setup while increasing handling... im talking the whole deal... lca's, uca's, tie rods, pan hard bar, shocks, springs, i also am going to get a tubular k member..... does anyone have any suggestions or could some of the tech guys tell me what a great setup would be thanks
Want smooth, stay stock, but add high quality shocks (KONIS). Aftermarket parts will have harder bushings or rod ends. These transmit vibration and impact---->no more smooth ride. Stock springs ride well, launch well and handle well. Higher rates will help handling, but at the expence of "smooth ride". You can lower your car 3/4" using the Koni SAs and stock springs, if you do want it lower, but again, less travel=more ride impact.
If your bushings and tie rods are worn, replace them, but understand ride smoothness is why GM compromised on performance in bushings.
Originally Posted by subtlez28
You can lower your car 3/4" using the Koni SAs and stock springs.
Koni Single Adjustable shocks - IIRC, it's the rebound of the shock you're able to adjust, but not the compression (You'd need DA's for both, but that's overkill for most). They also have two positions for the lower spring perches on the shock, and the lower setting gives you about ~3/4" drop.
LS1TECH Sponsor
You want it all. Ride, handling, etc. Nothing is free, but given the stock state of the cars, it's not hard to greatly improve things without hurting ride (actually helping it). But I have no idea what kind of driving you actually do, and what, in order of importance, you'd prefer to improve. I think you are doing yourself a dis-service by assuming you want or need all those parts.
Start with some good dampers, assess, move on to the parts needed to change the next big thing. That's how you test, and testing is how you don't overbuy or end up with something you hate.
__________________
