Help bleeding brakes
Old Feb 18, 2007 | 08:03 PM
Red_Dragon's Avatar
Default Help bleeding brakes
ok well i cant seem to get all the air out of the master cylinder. I had replaced it along with calipers. I bench bled the master the way it said to with the instructions i got with it which was with 2 plugs. That didnt work at all. i ended up going to the brake shop and had them presure bleed everything and wow what a difference. the problem now is one of my front brake lines broke. i bent a new line and got it in with no leaks but i need to bleed the master again. I have a mityvac that i got to bleed my clutch system, worked great on that. doesnt seem to work for me on the brakes unless im doing it wrong. is there anything i can buy to bleed the brakes like a shop does, will the mityvac work or should i go back to the shop? thanks for any advice im really not liking my brakes right now.
Old Mar 9, 2007 | 11:52 PM
DarkLoneWolf666's Avatar
Dude I need help with my problem. . LOLZ its funny but i was trying to put new rotors and i thought i was taking out the bolt that holds the clipper but i ended up taking off the line of the brake. . i shouldn't had been talking on the phone and not pay attention. . WHAT do i DO?? Do i just put new fuild??? PLESE RESPOND ASAP~!~!
