Seeking help with adapter fittings
I'm installing a C5 master cylinder in my 69 and I need adapters for the ports.
The front port is a 12mm / 1.0 thread ( I found an adapter at napa )
The rear port is a 12mm / 1.5 thread ???????
So far the only thing I have found is a banjo bolt that will fit.
The Napa part converts the port to 3/8 x 24 I.F.
What I would really like is adapters to convert to AN, I just bought this nice Rigid flare tool and would love AN fittings throughout the brake system. I have sourced Earls, Russell, Weatherhead, Pegasus, posted at corvetteforum, pro-touring, I refuse to give up, any help no matter how small will be greatly appreciated.
Matt
Matt
Eureka!! I found them while using Google to search for an online calculator of all things.
Here's the 411 :
C5 Master
Front port / rear brakes 12 x 1.0 metric bubble
Rear port / front brakes 12 x 1.5 metric bubble
Click on the first one for info on AN to metric fittings, $8.95 ea.
http://www.batinc.net/plumbing.htm
Here's the 411 :
C5 Master
