View Poll Results: Relocation bracket's Bolt on or Weld on!
Voters: 12. You may not vote on this poll
Relocation bracket's bolt in or weld in?
What is better/stronger the bolt in or weld in ones I already have LG subframes welded in so I am thinking of going weld in. What do you guys think.
I feel you will be fine with either one, we have never had an issue with our bolt on set-ups.
The Pro's to a bolt on style would be-
- They can always be removed and resold if needed (ex. Rear end swap)
- You can't install them wrong
- Then can be welded at anytime after installed
The Pro's to weld on style would be-
- Once they are welded and installed correctly you will never have to worry about them again. They are there for good.
Hope that helps!
Ryan
Hope that helps!
Ryan
Hope that helps!
Ryan
Hope that helps!
Ryan
Originally Posted by Out1aw
What is there exactly that you would have to worry about though?
Hope that helps,
Ryan
