shocks for a 1" drop
Old Mar 5, 2007 | 03:26 AM
GoFast908Z's Avatar
Default shocks for a 1" drop
did a search, yada yada yada, didn't find anything helpful
I'm getting the BRM sp01 springs cuz i'm only gonna drop 1".
I want to get some affordable shocks that are a good match for these springs. What do you recommend? Also, i heard the KYB shocks are crap and to stay away from them.
Old Mar 7, 2007 | 04:22 PM
GoFast908Z's Avatar
anyone?
Old Mar 7, 2007 | 07:50 PM
OldeSkool's Avatar
Koni is the cheapest adequate shock. Revalves will save you a little over konis but then you don't have the option of adjusting them.
Consider also using the koni lower perch and hose mod for about 3/4 to sometimes 1 inch drop without having to buy springs and live with harsher spring rates.
Old Mar 7, 2007 | 07:58 PM
vMaster0fPuppets's Avatar
call sam strano
Old Mar 7, 2007 | 08:56 PM
GoFast908Z's Avatar
Originally Posted by vMaster0fPuppets
call sam strano
isn't his stuff pretty expensive?
Old Mar 7, 2007 | 09:31 PM
Ace$nyper's Avatar
For what it is no, and comparing his prices to other places on same parts it's quite good.
Old Mar 7, 2007 | 09:41 PM
Derek_02's Avatar
You get what you pay for. Strano is the man and he will help you out.
Old Mar 7, 2007 | 09:45 PM
SGMZ28's Avatar
I've had no problem at all paying a few bucks (and I mean just a few dollars) more with Sam for the simple fact that his customer service well makes up for it.
Old Mar 7, 2007 | 09:53 PM
GoFast908Z's Avatar
what is his site?
Old Mar 7, 2007 | 09:55 PM
bearcatpride's Avatar
It's not necessarily the amount of drop the springs give when choosing appropriate shocks, but rather the spring rates that you should be concerned with
BMR's are progressive so an adjustable shock (Koni) would be your best bet
Old Mar 7, 2007 | 11:10 PM
GoFast908Z's Avatar
where can i get the Koni's?
Old Mar 7, 2007 | 11:11 PM
speed_demon24's Avatar
www.stranoparts.com
Call him up and talk to him.
Old Mar 7, 2007 | 11:40 PM
GoFast908Z's Avatar
the koni's and the re-valves are well over 500. too much for me.
Old Mar 8, 2007 | 01:06 AM
OldeSkool's Avatar
Shocks are easily one of the most important parts of your vehicle. They control everything about the way it rides handles and even stops. You probably paid several thousands of dollars for your vehicle and you can't cough up 500 bucks for good shocks.... that doesn't make much sense really.
Yes you can use cheaper shocks but they'll wear out instantly and you'll be bouncing along hating your car because it rides like pooh
Old Mar 8, 2007 | 01:43 AM
GoFast908Z's Avatar
I decided on the Koni SA, more affordable than what i first thought.
thanks for the help guys.
