Question about lowering...
Old Mar 7, 2007 | 05:45 PM
98-mongooSSe's Avatar
Default Question about lowering...
How important is an adjustable panhard rod when lowering the vehicle? I've got a solid BMR in place now that I've had on the car since it was new. My '02 SS already had the Bilstein suspension pkg from SLP, but I just changed to the Pro-kit springs & I'm curious how much this might be affected. Honestly, I can barely even see a difference the the rear height from the two sets of springs.
Any opinions?
Shay
Old Mar 7, 2007 | 06:06 PM
BlackHawk T/A's Avatar
Your rear will sit crooked, making one wheel stick out further, and the other in further. It can cause rubbing when using wide tires.
Old Mar 11, 2007 | 01:58 PM
Well I put a straight edge along the fender body line from front to back & measured how far in the top edge of the tires were. One side had 1" of clearance & the other had 1/2". Is having the rear end 1/4" off really going to make much difference? I couldn't even see the difference until I put a tape measure on it.
Shay
