control bars
Old Mar 8, 2007 | 09:25 PM
Nads06111's Avatar
Default control bars
What do you guys think of these control bars? Any good?
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 8, 2007 | 10:52 PM
subtlez28's Avatar
Boxed w poly bushngs will cause suspension bind during body roll----->bad times!
The stock LCAs are intended to flex to allow this articulation. This articulation is why (smart) people run rod ends on aftermarket LCAs.
I personally do not C what is so bad about stock LCAs, if you want a firmer bushing swap in som 1LEs.
Plenty of other areas to spend time and $ first IMHO.
But if U R set on LCAs, check out UMI.
Old Mar 9, 2007 | 11:26 AM
Sam Strano's Avatar
LS1TECH Sponsor
Subtle is correct, that type of control arm, regardless of who makes it binds the suspension in roll. They work great for wheelhop, but also hurt the ride and handling of the car as well.
I suggest a set of poly/rod-end LCA's $169 a pair, I happend to sell/use/recommend UMI's version. This style LCA doesn't have the binding because the rod-end will let the axle articulate. At the same time you get all the wheelhop/traction benefits of the arms you were looking at. FWIW, UMI also sells a regular poly/poly bushed arm too (and one with rod/rod ends as well).
I also sell the 1LE style solid rubber bushings for use in the stock LCA's, which are $52 for the pair. They help too by eliminating the air gaps in the stock bushings, which cause wind-up.
__________________
Old Mar 9, 2007 | 11:44 AM
Ericbigmac83's Avatar
Sounds like you got your answer, +1 on the umi poly/rod combo, they work great
Old Mar 9, 2007 | 12:00 PM
LPTXZ28's Avatar
I have those lake woods and they are really a piece of crap. The grease zerks have broken and ride is harsh.
Old Mar 9, 2007 | 01:33 PM
Nads06111's Avatar
what else would you sugest i spend the money on? i already have eibach springs and hyperflex bushings
thanks for the help
Old Mar 9, 2007 | 07:32 PM
SpdFrk1990's Avatar
What shocks do you have?
Old Mar 9, 2007 | 09:18 PM
subtlez28's Avatar
thanks for the help
1. Shocks--Koni SAs
2. Rod/Rod PHB (UMI)
3. Wheels tires (if you haven't already)
4. Cat back
5. Headers
6. Sway Bars (Strano)
Naturally these depend on what you have aready, what you want to spend, and what you intend to do w the car. But U R pretty safe w all these.
Old Mar 11, 2007 | 04:24 PM
3.4camaro's Avatar
1. Shocks--Koni SAs
4. Cat back
5. Headers
is that an e-34 M5 behind you in your sig pic?
