Everything I need?
Old Mar 9, 2007 | 11:58 PM
dnm12's Avatar
Default Everything I need?
So I want to put new rotors and pads on my car, I have decided to go with the duralast blanks after reading many posts here
-4 rotors
-Brake pads (what kind I want something that is great but not overly pricey)
-Anything else?
Old Mar 10, 2007 | 05:35 PM
dnm12's Avatar
Anyone pretty please...
Old Mar 10, 2007 | 09:19 PM
GTObsessor's Avatar
Hopefully some others will chime in but, if you want, stainless lines will help as well as a full brake fluid flush (I think Super Blue brake fluid is what most like on here) will benefit you if your car has some miles on it. Other than that, i think someone that knows more about brakes than I will have to chime in.
Old Mar 11, 2007 | 09:08 PM
dnm12's Avatar
Anyone else??
Old Mar 13, 2007 | 02:13 AM
dnm12's Avatar
Anyone???
Old Mar 13, 2007 | 09:22 AM
VIP1's Avatar
Copy & Paste Moderator
Here is what you need:
* 4 rotors (front and rear -- ex: AutoZone DuraLast or Brembo OEM blanks)
* 2 axle-sets of pads (front and rear -- ex: Hawk HPS)
Optional:
* New brake fluid to flush/bleed the system (ex: ATE Super Blue)
Here is a writeup on replacing the rotors and pads:
http://www.installuniversity.com/ins...ds_mwarren.htm
Do one at a time instead of jacking up the whole car though.
Here are some threads on bleeding the system:
<< Search isn't working right now>>
Also, while you are at it, grease up the sliding pins with a good high temp grease.
There are plenty more things you can do (upgrades etc), but that's all you really need
