Suspension Questions
1. Koni SAs (4 sweep from full firm, 1/2 turn from full soft)
2. Ground Control Coilovers w/ Eibach 350# front, stock rear springs??
3. Lower Control Arm Relocation Brackets
4. Spohn Adjustable poly-poly LCAs and Panhard Bar
5. Tailshaft mounted BMR Torque Arm w/ -1* pinion angle
6. UMI bolt-on SFCs
7. 275/40/17 tires
8. Alignment: -.5* camber, ~5* caster, 0 toe
9. stock 30/19 sway bars looking to upgrade
I am currently trying to optimize my suspension, great handling with as much straight line traction as possible.
When I purchase the car last year items 1-3 were already installed. Items 4-5 were basically free because I took them off the 1990 RS that I sold to my brother. Items 6-8 done by me and item 9 done by some Canadian guy.
My first question would be, why would the previous owner use stock rear springs (at least they look stock), not sure about the front spring rate.
My second question: I would like to upgrade the front sway bar to a 35mm solid ST bar (i know its heavy but not too expensive and baby on the way). I have a 24mm 1LE 3rdgen rear bar that i was thinking about using but not sure if i want all of that oversteer. Is there anyway I can tweak the rear suspension to compensate for the added stiffness of the rear bar or should I really look into a 21-22mm bar. If I went with 35/19 for a little while, what would I NOT like about that setup.
Thank you,
David
Why would the previous owner put stock springs on the rear coilover? I dont know. That's strange because it would only raise the rear end. Maybe he had a reason for that? I liked my stock springs setup with Koni's though, and won a local spectator drag event with that pair.
A 35mm front and 21mm rear is ideal for balancing things out. I would recommend tossing in a few extra bucks though and getting the hollow Strano 35mm front bar. That suspension techniques bar weighs a ton. Its about 15-20 lbs heavier than the Strano bar! I have one on my car. I could do curls with it for exercise
Are there any markings on the stock springs to be able to identify them.
Maybe they are 1LEs or something???
Also, I forgot to check but do the Eibach springs have markings on them to identify the spring rate?
Thanks again
The 35/19 combo is fine for me. Keep in mind the 35mm front will also stiffen the rear as well to a lesser extent. I would not upgrade the rear bar until you know the spring rates. If it is too soft in the back, then you can get some firmer springs (or mod factory ones like I did). With some 150's lets say it will really help the rear from leaning as well as contacting the bumpstop all the time. Then you can increase the rear shock rebound some to make the rear respond quicker to steering input or respond slower and get a smoother ride. So stick to the 19mm for now.
Have you already replaced the inner sway bar bushings with poly? That helps it to come into play sooner. You could probably add a little more camber up front as well. I run 1* and the front really sticks.
Have you played around with the tire pressures?
I can't determine the if the rear springs are stock based on ride height because it has ground control coilovers which are adjustable.
I guess thats the first thing I need to do when I have a chance is to figure out the spring rates.
Does anyone know if the Eibach springs are marked differently based on spring rate.
Another side question:
Does anyone know the spring rate for the rear springs from a 3rdGen ProKit.
I can always pull them off the car I sold to my brother and replace them with the springs on my 02 Z28. Ill probably do a search right now to see if I can find the result faster.
Here are mine:
The 1000 is the unsprung height (10")
the 250 is the inner diameter (2.5")
and the 0550 is the spring rate (550lb)
http://www.angelfire.com/my/fastcar/suspension.html
Yes, front springs look exactly like that, just have to check the numbers.
Yes, the rear springs (black springs) are sitting on the GC adjusting sleeves, but I will definitely get the car up this weekend and check everything out and try to find numbers on the rears.
Thanks again!
The front springs BTW are just generic race springs Eibach makes. They are used in all kinds of coilovers.
can't figure out what the rear springs are but there arent any markings and they look stock.
With the parts listed above and the front spring rate of 450# what is a good setting for the Koni SAs and if the rears are in fact stock, what spring rate should I look into getting if I decide to upgrade them. AutoX/road race setup.
Thanks
I want the set the car up for better handling so should I upgrade the rear springs to a higher rate to match the 450# front?
What rear spring rate would match better with a 35/19 and 35/21 sway bar setup?
I see Strano rear springs are 150# rears but his are set up for 550# fronts right?
Would something like rear ProKit springs 137lb (high end of progression) work well, or would I be better off with stock rear spring and a bigger (24mm) sway bar.
Thanks
I do find it odd that the adjustors are so low. Usually they are fairly high. One possible explanation is if the previous owner decided to cut the factory springs to increase their rate and lower their height to work better with the GC adjustors. Can you pull one out and take a picture?
Since the rear rate is unknown, here's what you can do. Buy some rear LS1 springs from a salvage yard for cheap. At least then you know what you are getting. 115lb/in. Each coil is worth about 20lbs. So if you cut off one complete coil the new rate will be 135lb/in. See how this feels. If you cut off 1/2 a coil more the rate will be 145/in.
This is much better than the prokit. Their rear springs are not so great anyway.
On adjusting the front Koni's, just set it to the middle (4 sweeps) and see how it is. If the ride is too rough, adjust it a sweep or two softer. If it feels good and you want more, adjust it a sweep or 2 firmer. I personally liked it as firm as I could stand. Once you get too firm the freeway ride gets kind of like a rollercoaster, your stomach just drops as the car drops on the low spots and it can make you quesy. So I softened it back up just a little.
Oh, and 450 is a good rate up front. No need to change out the springs for stiffer ones unless you just have to. Keep in mind the stock ones are 300 so it's a good bit stiffer.
Just get the 35mm front bar for now and then tweak your shock settings and tire pressures and see how the car handles. Only then will you know if you need a bigger rear sway bar.
Thanks again.
Since it won't sit flat in the rear anyway, some folks cut a new piece of tubing in a wedge shape and weld it in. It raises the mount and tilts it at the same time. I think others just let it ride kind of high.
