Vibration at 60
Old Mar 12, 2007 | 03:57 PM
Ego Killer's Avatar
Default Vibration at 60
I just installed a moser 9" on my 99ta and I noticed it is pulled over to the drivers side about 1/2-3/4 on an inch..nothing a adj.panhard bar wont fix but will that cause a Vibration in the rear at 60-65mph? or is it most likley my pinion angle?
Old Mar 12, 2007 | 04:19 PM
Studytime's Avatar
There's also a very good chance it's your driveshaft. With more aggressive gearing the driveshaft turns faster and vibrations are more prevalent as the factory only does a low-speed balance on stock driveshafts.
Ben T.
Old Mar 12, 2007 | 04:35 PM
Ego Killer's Avatar
I think I might have found my problem..my ujoint wasent setting down in the grove on my yoke and as I looked closer some of the needle barrings had come apart and got in the bottom of the cap caulsing(spelling?) it to set sideways..owell off the parts store
