hows this set-up?????
Old Mar 13, 2007 | 11:00 PM
sportsaddict_21's Avatar
Default hows this set-up?????
here is all my suspension and chassis mods. on stock rear springs. bought it this way.
Ground Control Front Coil-Over Kit
Koni Double Adjustable Front Shocks
Eibach Linear Rate 500 in/lbs Front Coils
Poly Bushing in front Control Arms
Supsension Techniques 35mm Front Sway Bar
Energy Susp. Poly Trans Mount
LG Torque Arm w/ Heim Joint Front Mount
Global West Dual Spherical Bearing LCAs
LG Adjustable PHR w/ Dual Heim Joints
Bilstein HD Rear Shocks (3rd Gen. Fbody Model)
LCA relocation brackets
Subframe connectors
Strut Tower Brace
just wondering. is this a good set-up with different springs and shocks/ should i invest in rear springs. sorry if its kinda confusing.
Old Mar 13, 2007 | 11:25 PM
i guess guys dont no wat im asking. Is it bad to mix and match the springs and shocks like that. and is haveing the stock rear springs hurting me????
Old Mar 14, 2007 | 12:22 AM
WolfgangX's Avatar
Personally I'd go with the adjustable QA1 hal shocks, i've read nothing but good about them. I wouldn't worry too much about your rear springs, unless you are going to lower your car they are hard to find.
Old Mar 14, 2007 | 12:55 AM
my car is already lowered.
Old Mar 14, 2007 | 01:49 AM
SIK02SS's Avatar
thats horrible advice. he has a front suspension and other supporting mods that are setup for cornering and your telling him to get a rear setup made for drag racing..
everything looks great except for the rear shocks/springs...
together they go well, but as far as the rest of your setup, its a bit mis matched. what do you want to do with the car? drag race? just street? some auto-x or canyons?
or call Sam Strano and talk to him about anything/everything you want to do with the car and he'll set you up
Old Mar 14, 2007 | 09:31 AM
PLucas's Avatar
My advice would be to call Sam Strano also.
I would get new rear springs(talk to Strano for his suggestion) and get konis for the rear also.
Old Mar 14, 2007 | 11:10 AM
THANKS im going to be mostly drag racing. but might get into auto-x. so i just dont want a drag racing set-up. the guy told me the car was built for the course. i guess i need to pick up so new springs and shocks for the rear. thanks guys.
Old Mar 14, 2007 | 11:27 AM
W105's Avatar
If you ever wanna get rid of those front shocks, just let me know!
Old Mar 14, 2007 | 11:58 AM
SIK02SS's Avatar
you might as well look into getting some koni s/a rear shocks and ground control adjustables since you've got them on the front...
but this will give you a mainly cornering setup...you can still pull some good times at the track though..just won't be getting the optimum or best times/results
