weld in SFC problem...
Old Mar 21, 2007 | 09:05 PM
catfSSh's Avatar
Default weld in SFC problem...
I rencently installed a set of 2 point weld-in umi subframe connectors on my 2000 SS. (which are an excellent product btw)
since then the car has developed a new noise
it sounds almost like a cracking where the sail panel is. i know fbodies arent quiet by anymeans but this noise wasnt there stock, and sfc's are supposed to reduce noises/creaks.
i double checked the bolt connecting through the LCA and it is perfectly tight.
im thinking either the welds are weak causing some shifting of the SFC or maybe they are making the frame too rigid, causing other parts of the car to flex.
anyone with some help would be appreciated
Old Mar 21, 2007 | 09:10 PM
Omec's Avatar
funny you ask that (well not funny that its making noise). i was woundering this today. i put in an order for bolt in SFC from UMI yesturday. hope someone chimes in.
corey
Old Mar 21, 2007 | 09:41 PM
crazymofo1986's Avatar
mine did that and i put it back up and retorqued it to specs (its alot more then u think) after that it went away
Old Mar 21, 2007 | 10:08 PM
catfSSh's Avatar
anyone know how much to torque the bolt going through the lca to?
Old Mar 22, 2007 | 07:29 AM
UMI Performance's Avatar
Torque those lower control bolts to 90 ft lbs and that should take care of the noise.
Ryan
