Another grinding brake question
Old Mar 26, 2007 | 06:16 PM
00HAWK#068's Avatar
Default Another grinding brake question
Last year I replaced my rotors with some drilled and slotted. I noticed a kinda creacking, grinding noise from the passenger rear. Did my searching and thought maybe clean up the pins and lube them, no help. The noise pulsates as I reduce speed. Any suggestions would help. thanks
Old Mar 26, 2007 | 06:32 PM
Monello's Avatar
If you feel the brake pedal pulsing as you come to a stop, like its grabing, going, grabbing. Then you have a warped rotor. Dont waste your time getting them cut, just replace them as cutting them doesnt make the rotor straight again.
Old Mar 28, 2007 | 06:03 PM
00HAWK#068's Avatar
No its not in the peddle its the sound that pulsates, could it be the emergency brake rubbing? I'm gonna pull it all apart again and start over and hope I can find the source.
Old Mar 28, 2007 | 06:37 PM
1bad ss's Avatar
let me know what you find mine is doing the same thing
Old Mar 28, 2007 | 06:44 PM
00HAWK#068's Avatar
I hope I find something , this makes me crazy
Old Mar 29, 2007 | 07:57 AM
Sneakyws6's Avatar
On the tree
I talked to one of the local performance shops that works on the F-bodies here in OKC. They have seen some cases including just recently with some of the Baer Eradispeeds that the rotor was warped from the factory.
I would pull the rotors, lube the riding area where the emergency brake shoes rides on the backing plate. Check the pins again to make sure they are lubricated and clean, make sure the pin dust boot it not torn. Make sure when the emergency brake is applied that both sides of the rear brakes are applied and holding and that one of the adjusters is not over adjusted causing the E-brake to drag.
Also drilled and slot cut rotors can be turned. I ahve turned mine with no issues and as long as the shop is competant and is using on of the newer brake lathes there should be no issues turning the rotors.
Old Mar 29, 2007 | 03:14 PM
99FBODY's Avatar
i had the same problem with my e brake and i just pulled it one day when i was going 30 down a side street and when i released the noise was gone
Old Mar 30, 2007 | 01:32 PM
00HAWK#068's Avatar
Thanks for the ideas, I will hopefully have time this weekend to get back at it.
Old Apr 2, 2007 | 05:00 PM
00HAWK#068's Avatar
Problem solved, I m a dumb a$$! I thought the noise was coming from the rear, NOT! I pulled the front caliper, cleaned the pins, Peretex the pad, all better now. Thanks for all the help.
