E-brake tension
Old Mar 28, 2007 | 06:57 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Default E-brake tension
Hey guys, I searched the stickies and did a manual search. I need an opinion about the E brakes.
I just recently put in a Moser 12 bolt in the car. I got the Ebrake shoe in place. I had turned down the adjustment all the way so I can get the shoe in and out during the install.
Now that everything is 95% done, ebrake brackets are in place on the rear. I am able the put the rotor on (note: new rotor, old ebrake shoe) and it slides on with no resistance, should I adjust the ebrake till there is a little resistance when I put it on??
I dont want to take my brakes apart 20 times do this. I was thinking leaving it just under tensioned and testing it from there.
Let me know.
Thanks!!
Old Mar 28, 2007 | 08:47 AM
Hugger Z's Avatar
You should be fine to tension it up so the cables are not too loose. There is an auto-adjust spring at the lever to keep slack out of the system as long as there is not too much slack in the rear cables. I would tension them just enough so they do not sag and flop around when you pull on them. That should be a good preload for the system and should work (lock the rear wheels) when you apply the lever inside the car.
Old Mar 28, 2007 | 09:07 AM
Internet Mechanic
I put the Ebrake bracket on the rear in the stock hole, I got one side clipped on, the other is next, seems like there is alot of spring in there. I had to push forward to get the spring clip in the hole.
I havent zip ties the rear yet, but that is next. I will keep you posted, any other comments are welcome!
