Bled Brakes.....Brakes still soft??
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I just recently bled my brakes the old fashioned way....(passenger rear, driver rear, passenger front, driver front) and for some reason my brakes seem a little softer than before the brake job....Any ideas on how to fix this??
This was my first time changing the fluid on this car, but I have done it before on another car with no problems....
Any help would be great!!!!
-James
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
-James
when i upgraded my brakes it took me and my buddy 3 times to bleed the brakes and get any air pockets out. We have bled brakes before so we were shocked it took so many times. We found that taking the car out on the road and hitting the brakes hard enough so that the ABS activates and then bleed the brakes worked the best.
Any more suggestions??
Originally Posted by DSMKilla
Are you doing it with the car on or off? I have found that they bleed better with the car RUNNING if you got power brakes.
Originally Posted by Disturbed Bird
maybe u have to buy new brake pads. just something to think about, or maybe u dont idk.
First, why did you bleed them? Did you open the system? if not there should have been no need to bleed unless you either opened the system/ changing out all the brake fluid, other than that doing pads should not require you to bleed the system.
It is recommended that you change brake fluid anually. Exactly how did you bleed your brakes, meaning what technique?
However if you have done the job before and things have turned out fine then you should know what you're doing. Thus I am puzzled by your post????????
One more thing, don't mean to insult your ability but since we can't see it through our computer screens.
Did you make sure that you put the calipers back on the right side....with bleeder screw up? If not you'll never get it bleed out.
