Polly stuff
Old Mar 29, 2007 | 12:03 AM
Sweet71's Avatar
Default Polly stuff
Hey what brand of tranny and engine mounts are you guys with aftermarket ones running, i tried a search but server was down or something and went on energy suspensions site but never saw anything....thanks for any help
Old Mar 29, 2007 | 08:11 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We offer the Prothane units if you are looking for a vendor.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Mar 29, 2007 | 10:40 AM
jimbo98z's Avatar
I've got energy suspension motor and tranny mounts, and I'll get part #'s for you if I can. I might still have the packaging.
Old Mar 29, 2007 | 12:23 PM
98ws61le's Avatar
Prothane units are a tad better then ES... i thnik the reason being for binding issues
Old Mar 29, 2007 | 07:59 PM
Sweet71's Avatar
cool, if u could get numbers that would be sweet jimbo
Old Mar 31, 2007 | 11:27 PM
OldeSkool's Avatar
I know you didn't ask, but I just have to throw in, I love poly engine mounts and hate poly trans bushings. But the trans bushing isnt expensive and its not hard to swap.. so never mind
Old Mar 31, 2007 | 11:30 PM
Duffster's Avatar
ES for sway & tranny mounts...
Old Mar 31, 2007 | 11:41 PM
3.4camaro's Avatar
solids
Old Mar 31, 2007 | 11:55 PM
BlackHawk T/A's Avatar
+2 for poly engine mount, and rubber transmission mount. If you drive your car a lot you will not want a polyurethane transmission mount.
I went with Prothane, they make a good product.
Old Apr 2, 2007 | 10:42 AM
gollum's Avatar
Any one make these mounts in Black insted of red. I would like my car to appear as stock as possible.
Old Apr 2, 2007 | 05:23 PM
Yes, Prothane does.
Old Apr 2, 2007 | 07:03 PM
gollum's Avatar
Originally Posted by BlackHawk T/A
Yes, Prothane does.
COOL ! Thank You
Old Apr 2, 2007 | 07:06 PM
gollum's Avatar
Why Not?
Old Apr 2, 2007 | 11:43 PM
DONAIMIAN's Avatar
Originally Posted by gollum
Why Not?
When used together (motor and tranny) a lot of people complain about the noise. The noise goes away when they replace the tranny mount with a stocker (while keeping the poly motor mounts)
Ive had a poly mount on my car since day one, so I dont know what a stocker feels like.
Old Apr 3, 2007 | 02:07 PM
OldeSkool's Avatar
Why Not?
You really dont benefit from it. unless you think interior noise and vibration is a benefit
Old Apr 3, 2007 | 03:00 PM
3.4camaro's Avatar
you will benefit if your shifter moves 2 inches to the right everytime you get on the throttle with the rubber. That's why I switched.
Old Apr 3, 2007 | 05:36 PM
OldeSkool's Avatar
the shifter moves because the stock torque arm attaches to the transmission tail shaft. generally its best to fix the problem (the torque arm) rather than trying to cover up the symptom (the moving shifter). but if the trade off works for you, good. like i originally said, trans mounts are cheap and easy. try it and see
Old Apr 6, 2007 | 04:53 PM
lsx24's Avatar
Prothane motor and trans mounts are what I used in the bird. Really stiffened up the drivetrain. Highly recommended. Shifts were more positive and consistant, and movement was quelled. Noticeable vibration at first, but after I got used to it I couldn't even tell something was different. When you go prothane, anything else feels like moving through peanut butter.
Old Apr 7, 2007 | 03:04 PM
Sweet71's Avatar
Cool thanks for the help guys....does anybody have the part numbers for the nrg or prothane engine mounts????
Old Apr 7, 2007 | 03:24 PM
lsx24's Avatar
Check Thunder Racing's web site...
