Want to convert my power steering lines over to -AN
I'm looking to convert my stock lines over to AN fittings. I know the reservoir side of the return line is just a hose slipped over and clamped, but I need the size of the other 3 fittings. I think I've heard both M16x1.5 and M18x1.5, and I know one of the fittings on the rack is bigger than the other from when I took it apart last.
Does anyone know the fitting sizes off hand? If not, does anyone know what I can measure to figure it out? I've been searching and searching and can't figure it out. Maybe I've been searching the wrong keywords, but either way, I need to figure out which fittings to order from Summit. I'm going to run 6AN line I think.
The PS pump is the same ole saginaw pump GM has been using for years. So it's commonly used in a LOT of applications.
I snagged the adaptors for my race car from a local dirt track shop.
Be aware, though. The HP side of the stock pump spikes a heckuva lot of pressure. Homemade AN hoses just barely fit within the spec. Be forwarned ... there does exist the possibility of you pushing off a hose.
Hmm good to know. I believe both of my lines are leaking, and I believe I can only buy a replacement pressure hose at the parts stores. I suppose I could just buy that line and make my own return line, but I wanted to clean up how the lines look a bit as I'm cleaning up the engine bay, and I also find those O-ring fittings somewhat of a pain to put back together sometimes.
Also had debated buying a PS cooler with 6AN fittings, which would've also been a big plus to the AN setup.
Thanks for the advice Mitch!
