painted rotor hats...need help
We did my cousins rotor hats..originally we used caliper paint, I forgot the name but it comes in a little can with a brush. We did not like the sheen of the gold color so we ended up using regular gold enamel paint, krylon with a clear coat, about 5 coats of paint and 3 coats of clear. Clean everything with brake cleaner first and rough the surfaces with some sandpaper....1 year later they are holding up great...
![](http://home.earthlink.net/~horsehitman/sitebuildercontent/sitebuilderpictures/27.jpg)
![](http://home.earthlink.net/~horsehitman/sitebuildercontent/sitebuilderpictures/26.jpg)
![](http://home.earthlink.net/~horsehitman/sitebuildercontent/sitebuilderpictures/25.jpg)
I used some Krylon high temp black spray paint on mine. I cut out a circle from cardboard to place over the hub and then a bigger piece with a hole to lay over the brake disc surface leaving only the area in between exposed. It worked fine. They've taken some real heat and held up well.
