Read end feels like it sways from left/right at highspeed
For some reason when ever going at a high rate of speed, 80+ it feels like the back end moves from left to right. I cant really discribe it but it reminds me of being on a snowmobile without picks, how the back end feels like its always sliding left/right.
What could possibly be causing this, as it does freak me out a bit.
Koni SA 4th Gen | DMS Springs | UMI Single adjustable LCA Poly/ROD | UMI Single Adjustable Panhard Bar Poly/Rod | UMI STB |
Fronts are set at 4 sweeps from full hard, backs at 25%
Also currently running 265/40/18 up front, 285/35/18 out back. Pilot Sport A/S
Any help would be great.
Thanks
Thanks
https://ls1tech.com/forums/suspension-brakes/639781-car-sways-left-right-high-speeds.html
Make sure you tightened the LCA's and rear suspension under load.
Going to try it today. I know for a fact that i tightened it under load, but that was with a jack in the center of the back axle in the air. Im going to place the car on ramps all the way around and then loosen it and redo it.
