Roll cage install
Old Apr 18, 2007 | 08:49 PM
SilentBobZ28's Avatar
Default Roll cage install
I'm gutting out my Z28 and I'm a decent welder. Is the install of a 10 pt roll cage terribly hard or would I be better off going to a seasoned shop here in Ky to have one installed?
Old Apr 18, 2007 | 09:03 PM
Out1aw's Avatar
If you have no experience then DEFINATELY get a shop to do it. TIG welding is recommended on any cage due to safety, and I would much rather pay more than have a faulty cage determening whether I live or die in a crash at the track. Plus there is a lot of math and geometry involved in doing a full cage, especially 10+ points.
Old Apr 19, 2007 | 12:33 AM
Yea, all i have is a mig and mostly all i've done is 4 links and stuff like that.
Old Apr 19, 2007 | 06:14 AM
mitchntx's Avatar
http://www.frrax.com/rrforum/index.php?showtopic=9223
A TIG weld is neater and tidier than a MIG. It doesn't add as much heat to the surrounding metal and it just looks better.
But a MIG weld can be just as strong.
If you don't have a mentor, like we did when we first started building 3rd and 4th gen cages, you can find yourself in a corner, waste a lot of tubing and/or build an unsafe cage. It's not as easy as it looks.
The finished cage in the link above had well over 200 man-hours in it.
