what would cause torque arm to snap
Old Apr 24, 2007 | 03:18 PM
black97ss's Avatar
Default what would cause torque arm to snap
i have a bmr non adjustable torque arm, well i noticed today that it has some cracks out by the mount on the rearend. just wondering how this happens? too much pressure applied to it? is there anything i can do to prevent it from happening again? any way to fix it without buying a whole new one?
Old Apr 24, 2007 | 03:31 PM
Old Geezer's Avatar
Could be caused by the fasteners being loose...
Old Apr 24, 2007 | 03:35 PM
black97ss's Avatar
so just make sure everything is always tightened up? throw some loc tite on there or what?
Old Apr 24, 2007 | 04:57 PM
BLKKNIGHTWS.6's Avatar
Are they actual cracks in the torque arm itself or surface cracks in the powdercoat?
Old Apr 24, 2007 | 08:35 PM
black97ss's Avatar
torque arm itself
Old Apr 24, 2007 | 11:55 PM
Breaking Stuff's Avatar
I had the same thing happen to my BMR, from what I hear it is common on Moser 12 bolts with any torque arm. The bolts loosen up or back out and the part that bolts to the TA snaps off. Not fun!
Old Apr 25, 2007 | 02:37 PM
black97ss's Avatar
so could you loc tite those? or just check them monthly? or how do i make it so it doesnt happen agian?
Old Apr 25, 2007 | 04:42 PM
Black02SLPSS's Avatar
I would personally use lock washers. But its up to you. those or lok tite
Old Apr 25, 2007 | 04:56 PM
DONAIMIAN's Avatar
Best way to go is saftey wire.
Old Apr 25, 2007 | 05:09 PM
02NBMWS6's Avatar
i had one break due to the bolts backing out when i had a 12 bolt in the car, and then another I broke with shear torque launching on ET Drags. The bracket that bolts the torque arm to the rear end broke when it came loose, and the the torque arm itself snapped the second time.
my guess is it was just overpowered when mine snapped, UMI replaced free of charge, even being as it was on a 12 bolt bc it was obvious that it wanst bc the bolts backed out.
Old Apr 25, 2007 | 05:10 PM
02NBMWS6's Avatar
mine had lock washers and loc tite when it came loose
i ended up just having to check them every couple hundred miles until i sold my 12 bolt
Old Apr 25, 2007 | 06:59 PM
I definatly agree with you there. Not gonna have that issue with saftey wire. Just gotta get the bolts drilled to take it tho..
02NBMWS6 What kind of a rear end are you running now out of curiosity? I figure ill need a new one once i get my 6speed swapped in.
Old Apr 25, 2007 | 09:46 PM
02NBMWS6's Avatar
i just got a new Moser 9in from EPP. Alum center section and TruTrac
Old Apr 25, 2007 | 11:09 PM
Old Geezer's Avatar
If the car is lowered, look for damage where the upper bar passes the rear seat belt plate.
Maybe a Random bar? have seen alot of them in the 9's. It's adjustable, too.
Old Apr 26, 2007 | 09:27 AM
black97ss's Avatar
now buying a umi one, ws6store is helping me out hardcore with my order!
Old Apr 26, 2007 | 04:44 PM
SpdFrk1990's Avatar
WS6 store has excellent customer service! So is this problem mostly just with 12 bolts?
Old Apr 26, 2007 | 08:51 PM
DONAIMIAN's Avatar
Yes, the moser 12 bolts because of the attatchment design. They like to use 4 bolts, 2 on top and 2 on bottom. Factory and strange uses 2 bolts that goes all the way through.
Old Apr 26, 2007 | 08:52 PM
SpdFrk1990's Avatar
Cool thanks
Old Apr 26, 2007 | 11:27 PM
black97ss's Avatar
yes ws6store i know one of the guys there so always have great service and they always help me out!
Old Apr 27, 2007 | 10:17 PM
3.4camaro's Avatar
your have a t-56 and an LS1. That is why.
