UMI order status
not trying to rush you or anything, i'm a patient person, and i know you guys are busy (hence the reason i didn't just call).....just wanna see how far along the order is, and if possible, get a tracking # (if it's shipped) so I can know approximately when the order will arrive and i can make plans
thanks
Hey Ryan, how's the family? I hope you've been more careful at deer stands ...
Next time I'm in town, I'll call and let you buy me lunch.
Mike said you hooked him up on the tubular K-Member. If you wanted it TESTED, he's the guy.
Take care and hope business is good.
-Mike
As for Mike, yes I got him all set-up and I am eagerly awaiting some results. I am sure he will have no issues and it should perform well for him.
On the order status, I thank you for the patience. However in order to check status I will need a name and/or order # to locate the order. Please PM me this info and I can look into it.
Thank you,
Ryan
I talked with Mike for a while Sunday evening and it sounds like the install was a cake-walk. Lot's of adjustment for camber/caster and fitment was excellent.
It's been a year or more since he's been on track, so I think you should have some feedback very soon. I think it's called Jones-ing?
using a telephone?
and got immediate feedback?
You can do that?
the best thing to do if you wanna know the status is either PM them here on the boards, or give them a call.....i PM'ed them, and they got back to me pretty quickly and gave me a status
PM me a name or order # and I can check it out for you.
Thanks,
Ryan
i did have to bang it a few times with a rubber mallet to get it to fit over the differential housing (presumably due to the thickness of the powdercoating), but i'd much rather have it fit just a little tight than too loose.
UMI has done a great job designing this adjustable torque arm, and i can only assume the same will hold true for the LCA's & relocation brackets (i'll update again when those come in and i have them installed). the wait time for their stuff is defintely worth it!
