Motor mounts
Old May 8, 2007 | 11:55 PM
wws699's Avatar
Default Motor mounts
What aftermarket motor mounts should I get? Search Is down and Im tired of doing it manually
WS6 store has prothane motor mounts and tranny mount for 60 bucks. Are these any good? Any recomendations? Searched several sponsers but got tired of doing that too?
Old May 9, 2007 | 12:12 AM
Emoney97ss's Avatar
i just put in those and took me and two other people almost four hrs.. those are a bitch to put in!!!
Old May 9, 2007 | 12:23 AM
Shock Hawk's Avatar
If it's a daily driver, I would go with poly's. Solids will work, but I hear they can be annoying in traffic, especially if you have a sticky clutch. Poly's give you the best of both worlds... stiffness and drivability. I hear that the solids are great as long as you're not in first gear (stop and go driving).
Old May 9, 2007 | 12:27 AM
wws699's Avatar
Are Prothane the same as Poly?
Its not really a daily driver, mostly weekend and track, but I do drive it on the street alot..
Old May 9, 2007 | 12:28 AM
wws699's Avatar
Yeah, I cant wait
Old May 9, 2007 | 06:35 AM
ZodiacZ28's Avatar
Yes Prothane are the same as poly. Prothane is the company. And poly is the material. Prothane or Energy Suspension make poly mounts for our cars. Just had mine put in. Like previously stated they are a PIA. I had a friend do mine for 150. Worth the money to me. What a tremendous improvement it made though. +1 for prothane.
Old May 9, 2007 | 07:15 AM
coolformula's Avatar
prothane motor MOUNTS is the one I have on my car! They work good and with the cam the whole engine don't shake like it did!
Old May 9, 2007 | 09:12 AM
Shock Hawk's Avatar
Yea, sorry. Half of everything is poly around here, I just forgot to say Prothane the one time it wasn't.
Old May 9, 2007 | 12:26 PM
blackbyrd's Avatar
when you put them in do you use the factory metal bracket or did you get a new one??
i got a set from energy suspension and have sense been told they dont even make them for the ls1 but i dont have the metal brackets and i was wondering if there is a company that sold them??
Old May 9, 2007 | 06:42 PM
GR33N GoblinM6's Avatar
i just completed my poly mount swap... Prothane Poly mounts from Summit racing.. around$50
i did mine while my heads and accessories were off.. and i did it as a 1 man job...
only pain in the *** i had, was drilling out the rivets in the clam shells.. kind of a bitch.. hammered in the new poly mounts as far as i could get them in, then used the bolts to pull the mounts in more and closed..
the other bitch was attaching the mounts to the block.. trying to line that up in the frame mount and to the engine sucked.. but once you get one in.. the other 3 are easier...
i got the long bolt for the driver side in, no problem.. then i lined up the passenger side as best as i could.. got a hammer and pouned that sucker in there.. had to hit it pretty hard, but its a 10.9 bolt so its strong...
Old May 9, 2007 | 11:53 PM
Emoney97ss's Avatar
when it wasn't lined up we got a long crow bar and moved the whole mount then got them in pretty easy only if we would have thought of that 3 hrs earlier!!!
Old May 10, 2007 | 08:11 AM
warp10's Avatar
I did mine while doing the H/C swap. 2 guys and it took us about 6 hours. PITA
The alignment was a pain.
Old May 10, 2007 | 12:26 PM
foxrus14's Avatar
Are you guys doing both side motor mounts or just one? what about the Tranny mount?
Old May 10, 2007 | 06:19 PM
MdFormula350's Avatar
prothane tranny and engine mounts, couldnt be any happier!
quite a few just do the drivers side since IMO its the easier of the two to get to and the engine lifts from that side as well.
Old May 11, 2007 | 08:45 AM
foxrus14's Avatar
Any vibrating with all three done?
Old May 11, 2007 | 08:19 PM
BlackHawk T/A's Avatar
The vibrations with the polyurethane mounts on automatic transmissions are terrible. Stock piece is going back in.
The motor mounts are great though.
Old May 11, 2007 | 09:43 PM
shoemike's Avatar
spohn solids.
http://spohn.net/category.cfm?categoryid=1083
