Brake fluid
Old May 14, 2007 | 02:29 PM
Choppers's Avatar
Default Brake fluid
How much brake fluid do i need to buy to do a complete flush and refill on my 1996 chevrolet Cmaro RS with the 3.8?
Old May 14, 2007 | 02:37 PM
cookba's Avatar
1 quart and you will have some left over just in case
Old May 14, 2007 | 03:52 PM
z28bryan's Avatar
It's good to have extra though. I ended up opening my 2nd quart working all of the bubbles out of the system.
Old May 14, 2007 | 03:54 PM
Choppers's Avatar
So 2 quarts of super ATE Blue would be plenty to flush and refill my system?
Old May 14, 2007 | 04:03 PM
Choppers's Avatar
that ATE Super Blue is expensive on amazon for 1 liter 8.99? Can i get it any cheaper?
Old May 14, 2007 | 05:04 PM
koolaid_kid's Avatar
Probably not. It is very expensive.
Old May 14, 2007 | 07:53 PM
Choppers's Avatar
so 1 quart or 2 quarts?
Old May 14, 2007 | 08:04 PM
Kage's Avatar
Cool
32 oz. and you'll be aight.
I use Valvoline Synpower Max ABS performance myself. Good chit man.
Old May 15, 2007 | 07:06 AM
ZodiacZ28's Avatar
I got mine from Sam and he recommended 2 quarts.
Old May 15, 2007 | 08:48 AM
CKZ's Avatar
CKZ
Same here.
Old May 15, 2007 | 08:52 AM
z28bryan's Avatar
2 quarts is a good amount if your doing a full flush. You definitely shouldn't run out unless you are flushing fluid in excess. 1 quart would be cutting it kind of close so it's good to have an extra. If you don't end up opening the 2nd bottle, you can use it another time.
Though I don't know if I would use the other half of fluid from the canister if I were doing a flush or bleed in the future since it was already exposed to air.
Old May 15, 2007 | 03:08 PM
Choppers's Avatar
thanks guys
